vcGeometrySet
The base class for any type of geometry set in a component.
Module: vcGeometry
Children: vcFrameSet, vcLineSet, vcPointSet, vcText2DSet, vcText3DSet, vcTriangleSet
Referenced by: vcCollisionRecord.GeometrySetA, vcCollisionRecord.GeometrySetB, vcGeometryContainer.GeometrySets, vcGeometryContainer.getGeometrySet(), ... (see more)
vcPickedTopologyCurveInfo.GeometrySet
vcRaycastResult.Set
vcVolumeDetector.getHitGeometrySet()
BoundingBoxvcBoundingBoxRGets the bounding box of the geometry set.
ContainervcGeometryContainerRGets the geometry container of set.
FeaturevcGeometryFeatureRGets the feature that the set belongs to in the node feature tree.
LayervcLayerRWGets or sets the layer that the set belongs to in the layout.
MaterialvcMaterialRWGets or sets the material of the set. If None, the set uses the default material.
NameStringRWGets or sets the material of the set. If None, the set uses the default material.
ShowBackfacesBooleanRWGets or sets whether to render faces that are not facing the 3D world camera (i.e. backfaces).
TypevcGeometrySetTypeRGets the set type.
deleteNoneNoneDeletes the geometry set from its container.
LicenseError: When no license for Modeling API.
ValueError: When the geometry set has no parent container.
